Management Packs
Enterprise Application Monitoring Library
The Enterprise Application Monitoring library doesn't make any changes to your environment directly, but is required for SquaredUp SCOM Edition v4's Enterprise Applications, as it acts as a base class for any Enterprise applications you map in SquaredUp.
While you can import this management pack without SquaredUp SCOM Edition v4, it will have no effect aside from allowing you to define your own EAs manually.
Current Version: 1.2.6 - 2022-05-16 - previous versions
Versions
- Version 1.2.6(2022-05-16)(Latest)Download v1.2.6
- Version 1.2.5(2020-05-23)Download v1.2.5
