Management Packs
Enterpise Application Monitoring Library
The Enterprise Application Monitoring library doesn't make any changes to your environment, but is required for Squared Up 4's Enterprise Applications.
Current Version: 1.2.4 (8/10/2019)
Download (52 KB)
The Enterprise Application Monitoring library doesn't make any changes to your environment directly, but is required for Squared Up 4's Enterprise Applications, as it acts as a base class for any Enterprise applications you map in Squared Up.
While you can import this management pack without Squared Up version 4, it will have no effect aside from allowing you to define your own EAs manually.
© Squared Up Ltd. 2019
Squared Up is a registered trademark of Squared Up Ltd. All other trademarks are the property of their respective owners. Privacy policy | Terms and Conditions
